Mark- Posted June 3, 2021 Report Posted June 3, 2021 Hello, Is it possible to have a FX3U-ENET module on the right side of the PLC and a FX3U-ENET-ADP on the left side? If possible, how to specify the module number in FX Configurator-EN? Regards, Mark
Neverov Posted June 3, 2021 Report Posted June 3, 2021 (edited) 3 hours ago, Mark- said: Привет, Можно ли разместить модуль FX3U-ENET с правой стороны ПЛК и FX3U-ENET-ADP с левой стороны? Если возможно, как указать номер модуля в FX Configurator-EN? С уважением, отметка Depends on which base controller you are using. You can check your build in the online configurator. https://www.mitsubishielectric.com/fa/ssl/products/cnt/plc_fx/ex/select/fseltool/fseltool.html I cannot answer the second part of the question. Edited June 3, 2021 by Neverov 1
Theuns Posted June 3, 2021 Report Posted June 3, 2021 The FX3U-ENET is configured via FX Configurator-EN so it is considered a "special function Module" If it is located right next to the plc it will be Module nr 0 , If you have a FX3U-4AD next to the plc and then the FX3U-ENET it will be module Nr 1 . The FX3U-ENET-ADP is setup via special relays and registers with Gx developer or Gx works 2. Refer to manual JY997D45801 for the FX3U-ENET-ADP 1
Mark- Posted June 3, 2021 Author Report Posted June 3, 2021 (edited) Neverov and Theuns, thank you. Edited June 3, 2021 by Mark-
