Hello guys! I have a problem with connection of SICK absolute TTL SSI encoder AFM60E-THTA004096 with OMRON NX102 controller over SSI module NX-ECS212. Does anyone have config for omron, or detailed description of data packet for SICK, with start bits of single and multiturn data packets? Thanks in advance!
 This should be the IO mapping for the SICK encoder on the ECS card
Edited by photovoltaic
I found out the following information
The position information looks like this:
- 12 bit multi; 12 bit sinlge; 3 bits error
- 24 bits position information
- 27 bits total information
The MSB is the most significant bit (the 1st bit of the multiturn, the 1st bit which is transmitted)
The LSB is the least significant bit (the last position bit of the single turn)
the data binding and ssi module settings in my project are like this.
After applying the new settings i always reload the module. But still got an error :(
What am i doing wrong???
Also - Do you have an NX-PF card on your PLC before this card? This card/encoder needs IOV and IOG to work and the IO power bus isn't fed from the CPU.
Thanks for reply!
Data lenght is 24bit not 30. So SICK techsupport from head office in Germany said. I have 1 NX-PF card and 2 NX-PD1000 cards. But encoder is connected to main power supply not to ECS212 card, because output voltage on it is only 3.2V. This is working remote system. The customer had a problem with the encoder and we recommended replacing it. Initially there was TR-Electronics cev582m and they bought SICK AFM60E-THTA004096. The old one worked and the new one could not be connected in any way.
Have you tried 24 bits and removing the status data? In the example I have there is no status data appended to ST/MT data.
