Hello, please help me deal with this problem. Mitsubishi GX Works 3. I can not understand why the TON function block does not work correctly. I need to set the timer in minutes, but if I set 55 minutes, the timer doesn't start and an error appears. How do I make a timer to avoid this? Going through the values, I found out that this happens with the numbers 55-110, although at times large numbers work adequately.
t_0 - DINT
flushing - TON
applyNewTime - Bit
Edited by nurgordeev
You have to change the resolution of the Long timer in the PLC parameters. It is set to 0.001 ms by default.
just change it to 1 sec and you can use the TON to 32767 sec  (9 hrs .....)
How then to solve this problem?
"Hello, please help me deal with this problem. Mitsubishi GX Works 3. I can not understand why the TON function block does not work correctly. I need to set the timer in minutes, but if I set 55 minutes, the timer doesn't start and an error appears. How do I make a timer to avoid this? Going through the values, I found out that this happens with the numbers 55-110, although at times large numbers work adequately."
Edited by Vladislav72
Just use multiple TONS, use regular timer/counters or use the special SM412 etc devices
We have a function block that increments a DINT off the one second timing flag - counts to over 60 years. Do it in ST and it will copy and paste across all PLC's (one of the best features of ST in my opinion).
