Hi, I am facing the strange problem with QCPU (Q03UDE) Controller, I have multiple modules in my project ( Analog, Modbus & Digital Modules) but after some time a random error comes and all my analog Chanel values hold the last values, meanwhile controller does not show any error in the diagnostic tool. After rebooting the PLC power Chanel values start to update. This thing happens randomly.
Kindly help me.
Thanks in advance
The values on the BFM hold its values.
X and Y of Analog Input Module is as follows.
Module Ready X is ON
Temperature Drift Compensation Flag X is OFF
High Resolution mode status flag X is OFF
Operating condition setting completed flag X is ON
OFFSET/Gain setting Mode Flag X is OFF
Channel Change Completed flag X is OFF
Maximum value / Minimum Value reset completed flag X is OFF
A/D Conversion Completed Flag X is ON
Error Flag X is OFF
Operating Condition setting request Flag Y is OFF
User Range Write Request  Y Is OFF
Channel Change Request Y is OFF
Maximum Value / Minimum Value  Reset Request Y is OFF
Error Clear Request Y is OFF
No i did not connect mitsubishi.
Previously i just changed my power supply from q61p-A2 to Q64p because there was an error on the PLC error code is 1403 unsupported module is mounted.to resolve this error i replaced my power supply on main chashis with q64p. after replacing the power supply the error 1403 did not occur again but this happened that all my analog inputs modules channel values hold its last value after random time like after 12 hrs or 18 hours.and after power off the plc supply it works normally.
