Tech789 Posted July 29, 2021 Report Posted July 29, 2021 Hi, I have a new FXU5-32MR/DS with GX Works 3 version 1.070Y and I can't read it with direct connection ethernet RJ45. I have upload 4 printscreens. I really don't know how to resolve that. I am new with the Mitsubishi brand. Do I need an SD card ? Regards, Thank you
Gambit Posted July 30, 2021 Report Posted July 30, 2021 ??? It's a new PLC. There is no program in it yet. What would you want to read out ??
Tech789 Posted August 2, 2021 Author Report Posted August 2, 2021 Hi, I just want to test before programming I did exactly like in this video: https://www.youtube.com/watch?v=p7YM9_D8ZlM&ab_channel=IGSElectronics He doesn't have a program in the PLC and it work. Why not me ? Regards Thank you
glavanov Posted August 2, 2021 Report Posted August 2, 2021 New plc from the dealer have only firmware installed and blank parameters and program memory. Just create new project in gxw3 and write it to the plc for parameter initialisation. Default Ethernet port IP adddres is 192.168.3.250 You may want to change it to somthing more suitable for your local network before writing the project. You can always write your rpgram later.
Tech789 Posted August 2, 2021 Author Report Posted August 2, 2021 It worked really good now. After this, I will need to connect a GS2110 Thank you very much
