pioneer5900 Posted August 2, 2021 Report Posted August 2, 2021 hi all, i have a omron nt2s-sf122b-ev2 model hmi and i am using cpm1 type plc i have a plc-hmi cable and nt2s-pc cable ,i can send new program on the hmi but my plc registers is not working i checked to forums and i found nt2st program is better for old hmi programming but its not working on windows 10 also i tried to xp service pack 3 mode i need windows 10 program or must i use nt2st v1.03 on win xp ? thanks for helping Quote
viman Posted August 3, 2021 Report Posted August 3, 2021 I had to set up a virtual machine with winXP to be able to get NTST working (older software). See my thread down this subforum, https://forums.mrplc.com/index.php?/topic/40250-nt-suport-tool-data-created-by-dos-tool/ Quote
IO_Rack Posted August 3, 2021 Report Posted August 3, 2021 NT2S does not use NTST. The software was a separate download. This LCD display is very, very old and I wouldn't expect the software to work on anything newer than Win XP. You should consider replacing it with an Omron NV series. They are inexpensive and NV Designer comes with CX One. Quote
viman Posted August 4, 2021 Report Posted August 4, 2021 I know. But he's going to need that virtual machine if he wants to use whatever software that display needs. Quote
