Hi, I'm a student undertaking a project based on siemens s5. I want to make a device to monitor a temperature sensor. This sensor has a thermal resistor inside, and the resistance changes value with the temperature. The plc is to compare the input from the sensor and a set point. It will then send different signal depending on the resistance of the sensor. Now, I have a siemens analog input module, serial no. 6ES5 464-8ME11 v.06. Is this module capable of doing what I want? Thank you very much for your support and help! Patera
