AndersonJr Posted August 23, 2021 Report Posted August 23, 2021 I need help, with a mitsubishi servo motor model mr-je-b, I have a rotary knife application. But I define the length of my product and the cut is always being done with the same size. Has anyone had this problem? I need help, with a mitsubishi servo motor model mr-je-b, I have a rotary knife application. But I define the length of my product and the cut is always being done with the same size. Has anyone had this problem?
panic mode Posted August 23, 2021 Report Posted August 23, 2021 Motor itself is the least interesting component here. you should specify what controls the motor. There needs to a servo drive or servo amplifier and some sort of positioner, usually PLC... How does defined length get entered? How is the value used?
AndersonJr Posted August 24, 2021 Author Report Posted August 24, 2021 Good morning, my application is already assembled. My servo motor and an external encoder latch positioned on the shaft of a frequency inverter. As you can see I put the program in the attachment. I am changing the size of my product via U1\G53210 .
glavanov Posted August 25, 2021 Report Posted August 25, 2021 (edited) I think you should change product size by Sheet Lenght (G53206). Edited August 25, 2021 by glavanov
