troido Posted September 2, 2021 Report Posted September 2, 2021 Hi, I am trying to connect to an MR J3 amplifier using MR Configurator and a usb cable. The PC does not recognize the Amplifier due to missing driver. Driver does not get registered during installation as it is not compatible with x64 system. Is there any workaround? Is 64 bit driver available? Thanks!
panic mode Posted September 2, 2021 Report Posted September 2, 2021 you did not mention version of MR Configurator. well one workaround is to boot older 32-bit OS. i think Win98...Win8 were supported but Win10 has been out for some time so i would expect newer version to exist. did you check Mitsubishi software downloads or tech support?
Crossbow Posted September 8, 2021 Report Posted September 8, 2021 Likely your MR Configurator is out of date.
