NgoHoang Posted September 8, 2021 Report Posted September 8, 2021 Dear I'm studying PLC Omron NX1P2 series. I'm facing an issue with "_sSOCKET_ADDRESS" data type in SktTCPConnect function block. Could you tell me how to define the value for this datatype in SysmacStudio? which is format for "_sSOCKET_ADDRESS" data type Ex: I want to declare DestAddress is 192.168.1.123
IO_Rack Posted September 9, 2021 Report Posted September 9, 2021 _sSOCKET_ADDRESS is a pre-defined Structure in Sysmac Studio. Here are the elements of the structure: There is syntax to populate the Initial Value field but I find it easier to do it in PLC code.
Crossbow Posted September 9, 2021 Report Posted September 9, 2021 If you click in the Initial Values column, a black box appears, and when you click it, you will see each member of the structure and can enter data that way too, if it doesn't need to be changed. Also keep in mind the IP address is a string, so it needs to be in single quotes '192.168.250.10'
