panic mode Posted September 8, 2021 Report Posted September 8, 2021 View File simple backup utility simple command line backup utility. monitors one folder and when files of given type are detected, they are copied to another location (or two). original can be deleted or renamed. to avoid typing, all options are stored in an INI file. if missing, this file is created once the program is started... successful actions are highlighted in green, failed ones are red. this should also work on older Windows such as Win2K (tested) and WinXP (not tested). use at own risk, this was literally something i just winged... if there is a bug or feature required, let me know. i will try to get to it as time allows. Submitter panic mode Submitted 09/08/2021 Category Free Utilities
