KCRP Posted September 9, 2021 Report Posted September 9, 2021 Hi, I am using IQ-R Series "R16ENCPU" With Inbuild CC-LINK IE FIELD "RJ71EN71" and attached CC-LINK "RJ61BT11". Problem is, Even though my remote IO cards are in Online connected with masters, I cannot able to On/OFF Remote Device station IOs in CC-Link IE FIELD network. But CC-Link Normal is working fine. Refresh settings and Network Config Settings are done, Below attached the pics for reference. I cannot able to find the problem, Can anyone help me in this.
Gambit Posted September 10, 2021 Report Posted September 10, 2021 (edited) first I see that in the CC-Link IE Field network the inputs are refreshed to X2000 but i think you want to use X200. So if you activate Y200 - Y21F no output light turns on on the first slave of the IE Field network ? Edited September 10, 2021 by Gambit
KCRP Posted September 11, 2021 Author Report Posted September 11, 2021 Hi @Gambit ,Thanks for a reply. Actually my refresh settings is X2000 AND Y2000 and I tried with X2000 and Y2000 i never get a ON/OFF signal. Then i change to X200 and Tried also no signal.
KCRP Posted September 11, 2021 Author Report Posted September 11, 2021 Initially i configured Refresh setting for CC LINK IE FIELD is X2000 & Y2000 also cannot get signal
KCRP Posted September 11, 2021 Author Report Posted September 11, 2021 See below Pic for the Communication in between the remote devices.
DaMro Posted September 21, 2021 Report Posted September 21, 2021 Hello Did you set up modules parameter: Initial parameter setting to "Without initial processing" ?
