Hi all,
Currently, I have plan to using MR_J4_10A_RJ control by Modbus-RTU.
During read manual of this servo driver I see Mitsubishi offer many control mode.
Can any one have help me to distinguish "Position control" and "Positioning" ?
Hi
In position control the servo follows the command pulse signal from for example a PLC.
In Positioning mode the servo is controlled internally. Point table is a table with pos, speed, acc, dec ..... values and can be executed by DIO. Program mode is small programs also controlled by DIO. Indexer mode is a rot coordinate. These three modes can be controlled by communication.
Remember to init the servo amp in Parameter PT34 when using positioning mode.
  • Like 1
Thank GreenMan,
I'm still not fully understand, my concern is:
If i'm using Modbus-RTU to control this servo driver then "Position mode" or "Positioning" still available -> I can used command to control both "Position mode" and "positioning".
In positioning, i can write specific value to No of table: Target position, speed, acc, dec -> I can control one table no (Example table no 0) like "Position mode".
Pls help to correct me if i was wrong.
When i need to used "Position mode"/"Positioning" incase i control servo driver by Modbus-RTU.
