Hello,
I am started working on Gx Works 3 recently, actually want to know if I can access local labels from other program body or can call them to other program body?
Actually I thought I could access them like "Local Label Program body name"+"."+"Label Name", like other plc software does, is that possible in Gx Works 3?
You can use that style when accessing a label inside a FB but not for labels.
The def for a local label is that that label is only used there so what would be the point ?
nevertheless i'll give it a try
  • Like 1
