Neverov Posted September 25, 2021 Report Posted September 25, 2021 (edited) A working controller FX3 on factory. It was necessary to subtract the project (using GX Works2) to save it in case of a PLC breakdown. Never faced such warnings before. What could it be because of? How to make sure that the read project can be used in the event of a PLC breakdown? Edited September 25, 2021 by Neverov
Gambit Posted September 27, 2021 Report Posted September 27, 2021 you're program creation was for just ladder. You should create a program in structured instead and read out the program againhttp://.
Neverov Posted September 27, 2021 Author Report Posted September 27, 2021 14 hours ago, glavanov said: What is your ver. of GX W2 ?
Neverov Posted September 27, 2021 Author Report Posted September 27, 2021 (edited) 12 hours ago, Gambit said: you're program creation was for just ladder. You should create a program in structured instead and read out the program againhttp://. That is, before reading the project, create an empty project ? And only then read? Immediately after opening the program (without creating a new project), I clicked to read the project. Edited September 27, 2021 by Neverov
glavanov Posted September 28, 2021 Report Posted September 28, 2021 Don't know if this is the issue,but...
Gambit Posted September 29, 2021 Report Posted September 29, 2021 On 27-9-2021 at 8:55 PM, Neverov said: That is, before reading the project, create an empty project ? And only then read? Immediately after opening the program (without creating a new project), I clicked to read the project. Try using ladder instead of structured ladder with use label checked. !!!
