I want to establish Ethernet IP communication between the following PLC CPUs.
Schneider Electric - BMEP582040
Honeywell - ControlEdge UOC CPU900-CP1.
Where the Schneider must be master and Honeywell must ne adapter.
Let me know if anyone have done this or can help me to do so.
I'm a Modbus guy, I've never done Ethernet/IP, but I have had a minor run-in with the UOC.
The UOC is a Honeywell ControlEdge 900 controller running the Honeywell control execution environment (CEE) configured with Experion Control Builder, the UOC development software, which is a licensed software product.  Honeywell calls its versions 'releases'.   I do not know if a later release is backwards compatible with an earlier release.   Make sure you have access to the development software.  It's pricey.
A Google search will locate the 50 page manual for the ControlEdge family of CPUs (of which UOC is one), EtherNet/IP User's Guide, document # RTDOC-X548-en-160A, dated from Jan 2020, link below:
https://www.honeywellprocess.com/library/support/Public/Documents/ControlEdge-PLC-EtherNet-IP-Users-Guide-RTDOC-X548-en-160A.pdf
The Function Block section of the manual with the Ethernet/IP FB's is attached.
It isn't clear to me how two 'controllers' talk to one another, as opposed to a controller talking to a field device, like a flow meter.   With two controllers, who is consumer and who is producer?   Is that where an 'adapter' is used?   The Honeywell Ethernet/IP manual might shed some light on the 'adapter' situation.
Enet-IP FB's from ControlEdge-Builder-Function-and-FB-Configuration-Reference-Guide-RTDOC-X286-en-151A.pdf
