aliansari Posted November 1, 2021 Report Posted November 1, 2021 (edited) Hello, I have 1 PLC with 2 ETN21 Module, one of them(node 0) already configure for HMI, I want to know how can I use the second one (node 1) to configure as Modbus server with DCS. without change node Number. Edited November 1, 2021 by aliansari
photovoltaic Posted November 1, 2021 Report Posted November 1, 2021 https://www.myomron.com/index.php?action=kb&article=1245 You'll need to use the ETN that is setup for unit 0 for the server but this function block should work
aliansari Posted November 3, 2021 Author Report Posted November 3, 2021 thank you for your replying, unit 0 is working, but this already used by HMI, but unfortunately I haven't access to HMI to change that. I want to know if there is another way to apply this without change unit 1.
photovoltaic Posted November 3, 2021 Report Posted November 3, 2021 I haven't tested this but you should be able to do Modbus and FINS from the ETN21.
