Artz Posted November 10, 2021 Report Posted November 10, 2021 Hi Apologies in advance, this is probably something very much asked in forums, but my mind does not get why this issue is happening. My variable: ERROR_LECTURA_REF_OVERVOLT[1] is not reset whenever my Temp_ten_ref_o_1_h TON output reachs the coil on the '203' rung. But instead making use of BTN_HMI_ADV_VOLT_READ_OK variable works right. Why is this? State 1 : State 2: Setting a high value for LECTURA_REF_LTS_OUT triggers the coil State 3: Rung '203' TON Q output reachs the coil ERROR_LECTURA_REF_OVERVOLT[1], this variable state stays active until I set down LECTURA_REF_LTS_OUT value on rung '66' State 4: ERROR_LECTURA_REF_OVERVOLT[1] is not reset despite the coil at rung '66' is not active (Why?) State 5: Input BTN_HMI_ADV_VOLT_READ_OK is set to true and once is false ERROR_LECTURA_REF_OVERVOLT[1] is reset Final state (state1):
photovoltaic Posted November 10, 2021 Report Posted November 10, 2021 Are you able to share the project?
Artz Posted November 10, 2021 Author Report Posted November 10, 2021 It worked... I knew nothing about that "race condition" it's something I could not learn about unless I experience it, I must be careful with this issue in the future. I owe you one, thanks a lot!
Artz Posted November 10, 2021 Author Report Posted November 10, 2021 18 minutes ago, photovoltaic said: Are you able to share the project? I cannot it's part of my company politics I work for.
