Hi!
I would like to do some tuning on our machine, but the problem is that the machine stops and drops origin positions.
I selected User Command method with Basic setting. After 5sec I started the tuning, the machine stops with the roblem of that axis.
Is there a parameter bit that goes high (or low) during tuning? There're no strange sounds nor movements..even the amplifier doesn't give error code.
Is there something else that i should check?
In the Servo-Adjustments parameters, One Touch Tuning setting I found the Permissible Overshoot Amount Level is set to 0.  Can it be the problem?
Edited by Gman1
  • Like 1
