Hi team;
I am struggling with a Citect SCADA read of some data. The system is using the "Modnet3" driver over TCP/IP to talk with a system (Modnet 3 as its TCP/IP with first register at 0 and 0 to 15 bits). I am reading the modbus data into variables which is working fine for the analogue values all defined as real in citect.
The Issue I have is that the driver help says I can direct reference a bit in a word, in my case address 45052.1 Holding register 45052 and Bit 1. If I read this as a UINT I get a value of 147 corresponding to bits 1,2,5 and 8.
Citect generates no errors for the tag setup where I define 45052.0 through 45052.15 but all remain as zero in tag lists.
Any help would be fantastic
Kindest Regards
Howard
Hi @hmwright I have create test project for MODNET3 bit in word.I have found that bit order on wor device is seperate into 2 block.
I will describe below.
1. Create project with I/O Device to use Modnet3 (If necessary assign device address).
Citect_Modnet_Bit_01.jpg.dcd6d2a21e7e093
2. Create Variable tag with word and bit in word (For Modnet3 address start from 0 and have bit 0 - 15 that means in you need to read device that start address are 400001 you should assign in citect as 400000).
Citect_Modnet_Bit_02.jpg.983d1977930144c
3. Compile and run project when assign word value is 147 then bit 8, 11, 14, 15 are on.
Citect_Modnet_Bit_03.thumb.jpg.02a94a63c
4. That because in Modbus data is arrange data from bit 16 to bit 1
Citect_Modnet_Bit_04.jpg.2eaf58655c9ac04
5. If you need to start with bit 1 you should config parameter [MODNET]RegisterBitReverse from 0 to 1.
Citect_Modnet_Bit_05.jpg.728fa33b73c5f90
6. Select Setup Editor to edit Citect parameter.
Citect_Modnet_Bit_06.jpg.fcd823ac38a16d5
7. Add Section MODNET then edit parameter as shown below then click "Add" button.
Citect_Modnet_Bit_07.thumb.jpg.6aa6b759e
8. Go to File -> Save to save parameter.
Citect_Modnet_Bit_08.jpg.a6db0a6055e2bd9
9. Then Reload parameter and close window screen.
Citect_Modnet_Bit_09.jpg.d2e39c910471c84
10. When run project again for value 147 bit 0, 1, 4 and7 will on.
Citect_Modnet_Bit_10.thumb.jpg.665d18dfa
