Septimer Posted December 14, 2021 Report Posted December 14, 2021 Hi all, I am a new user of VB.net on NA Omron HMI, and I need your help to solve a problem. In my case, I have to get a HMI global variable value in VB.net, but the VariableName is in an other variable (string). For example: Var1=4 Var2=6 VarName="Var1" I worked with a "SetVariable" function to modify the value of different variables, but right now I need to read the actual value, in the example values 4 and 6. Do you have any suggestion?
IO_Rack Posted December 14, 2021 Report Posted December 14, 2021 (edited) The data you are interested in is most likely derived in a PLC. The PLC is capable of Socket Services. (This is assuming the PLC is an NX or NJ.) This would require some PLC programming. Edited December 14, 2021 by IO_Rack
Septimer Posted December 14, 2021 Author Report Posted December 14, 2021 27 minutes ago, IO_Rack said: The data you are interested in is most likely derived in a PLC. The PLC is capable of Socket Services. (This is assuming the PLC is an NX or NJ.) This would require some PLC programming. Thanks for your answer IO_Rack, I am interested in the value of the HMI global variables. The access to that variables seems easy with the SetVariables(ByRef VariableName as object, Value as object). My problem is that I dont found a function like "GetVariable". Kind regards.
IO_Rack Posted December 14, 2021 Report Posted December 14, 2021 I misunderstood your question. I'm still a little confused. Where do you want to read it? If you need to convert the data type, you can use VB.net functions like MyInt = Convert.ToInt32(MyText);
panic mode Posted December 14, 2021 Report Posted December 14, 2021 if i understand, the problem is not pasring the value but actually reading value
Septimer Posted December 14, 2021 Author Report Posted December 14, 2021 50 minutes ago, IO_Rack said: I misunderstood your question. I'm still a little confused. Where do you want to read it? If you need to convert the data type, you can use VB.net functions like MyInt = Convert.ToInt32(MyText); I want to read in the vb.net subroutine. I don't need to convert the string to integer, I need to get the value of the variable that the name is written in the string. I have three variables defined in the HMI global variables: str_prueba (as string) m_prueba (as Integer) m_prueba2 (as Integer) To change the value of m_prueba and m_prueba2 I used the following code: sub prueba str_prueba="m_prueba" setVariables(str_prueba,1) end sub Changing the string (str_prueba) I can access to the diferent variables and change the value of these. But, now i want to get the actual value of the variables as the same way, changing the variablename in the string. thanks for your patience.
Septimer Posted December 14, 2021 Author Report Posted December 14, 2021 (edited) 2 hours ago, panic mode said: if i understand, the problem is not parsing the value but actually reading value Edited December 14, 2021 by Septimer
panic mode Posted December 14, 2021 Report Posted December 14, 2021 and if i am not mistaken you are using NA terminal (in which case there is no VB.NET) https://assets.omron.eu/downloads/manual/en/v3/v118_na_series_programmable_terminal_software_users_manual_en.pdf
Septimer Posted December 15, 2021 Author Report Posted December 15, 2021 (edited) 16 hours ago, panic mode said: and if i am not mistaken you are using NA terminal (in which case there is no VB.NET) https://assets.omron.eu/downloads/manual/en/v3/v118_na_series_programmable_terminal_software_users_manual_en.pdf I am not sure but I read that Omron NA panel works in VB.net. If it is not I am sorry I am new in this type of programing. https://www.myomron.com/index.php?action=kb&article=1650 Any sugestion about how create "getVariable" or get variable value? Edited December 15, 2021 by Septimer
IO_Rack Posted December 15, 2021 Report Posted December 15, 2021 I'm sorry that I don't understand where you wish to "Get" the variable. What do you want to do with the value? You can make it equal to another string like this: Sub GetMyString Str_MyOtherString = Str_MyString End Sub You can display it on the NA with a Data Display object by simply putting the variable in the Expression field. No VB.net needed.
