Newbie123 Posted December 19, 2021 Report Posted December 19, 2021 I'm currently migrating panelbuiler32 to factorytalk view project running in a laptop. Panelbuilder32 (panelview 600) use Devicenet communication but now, factorytalk view will use Ethernet communication to plc. My problem is not all I/O slave hmi tags defined in panelbuilder32 can be seen when browsing Online tags from Factorytalk Linx. Can you help how to map the devicenet tags to PLC tags using the I/O address? Devicenet module is in Slot 9. Upon checking the Scanlist from RSNetworkx, I/O parameters is Polled with 128 bytes in Input and 128 bytes in Output.
Newbie123 Posted December 19, 2021 Author Report Posted December 19, 2021 Here are some screenshots for reference. Thank you in advance for your help! :)
