I have a screen with several variables displayed to an end user that indicates results of a test run. How do I save this data values to the plugged in USB drive?
Display screen will have the following format.
Run ID # (integer)
User Name (String - 20 characters - 11 Bytes)
Batch ID# (integer)
Test Data 1 (Real)
Test Data 2 (Real)
Test Data 3 (Real)
All these are contiguous %D Memory addresses (D100 to D119) read from the PLC that will be shown on a HMI screen.
Upon a button press, I would like to write this data on to a CSV or a text) file shat will be saved to the plugged in USB drive. Is this possible? File name can be either the RUN ID or the BATCH ID.
Thanks.
You could save a screenshot, or setup datalogging on a trigger (which would be the cycle finished indicator). It would be easier to do it in the PLC I think, save it as a CSV to the SD card
