Hi All,
Please can you assist.
I am trying to create a "delay" to slow down the rate that an action takes place.
I place a TON function black, but once run once it does not reset.
I need to know what function I need to put in the following rung or at the end of the rung to reset the TON function again.
Basically want to check a condition every 5 seconds.
Any ideas?
Many thanks
Hi, Thank you for your kind response.
Your solutions makes sense, however, it doesn't see to be carrying through for me.
Where am i going wrong?
The ton_3.q bit is only true for a single cycle so you won't see rung 14 progressing, I recommend paralleling a test bit on rung 14 so you can see what is happening. You could also latch a test bit at the end of the rung to see if the rung power is making it through when needed.
Thank you to you all for being so kind as to share your knowledge and ideas to assist me.
With a combination of your inputs, no pun intended, i have solved my puzzle.
I used 2 timers to create a Filpflop, the second resetting the inverted input on TON.I of the first timer and visa versa
Works like a charm.
Thanks for the help
