Dear all, I have an Omron inverter 3G3TC-AB004, which apparently there is not much information about it online.
I have successfully connected this inverter with Modbus, and able to change some of its parameters from Modbus Poll, yet I still haven't found the address for the Start and Speed Command. I've tried to set the frequency from modbus but unfortunately it's a read only register.
Is it possible to control this inverter from modbus or it's only useful for monitoring the inverter status?
Thanks in advance.
Edited by too_high
With Modbus Poll try f4 instead of f3.
F3 = function 3. f4 = function 4.
Try with f4, which should let you write to the registers one by one, until you find what you need.
I hope I helped and that you find what you need.
