Abdelrhman Posted February 14, 2022 Report Posted February 14, 2022 At the server Citect scada runtime problem, it shows bad, and com problem although opc server is running correctly, and work station runtime also running normally
slimskism Posted February 18, 2022 Report Posted February 18, 2022 You probably need to post a bit more information here to get a reasonable answer to your question. What PLC are you using? Which communication protocol? How is everything connected together? #BAD and #COM means Citect cannot connect to the PLC.
