I am trying to get a NT 21 to link to a CPL1
I have both set to Host link 9600/7e2
I have it set to read a DM
All I get is system initialzing
I am using the same cable i used to build the screens with NT Series Support tool
I sent and recieved the screens so the cable works
The com port on thee PLC is flashing
I have tried starting the PLC in run mode and Monitor Mode
What did i forget to do ???????
Rob
First word in the status control area should contain your initial screen number.
Most likely it is zero.  There is no screen zero.
gtsuport
gtsuport
Thank you for the reply.
I will check that.
OK I read and read but cant find any info on seting up the NT21 beyond making up screens
I cant find anything on Status Control Area
Can you elaborate a bit more...
What bit controls the screen?
Thanks in advance
Rob
In the Tools pull down menu, there is PT Configuration.
In the configuration, there is a tab for Control/Notify Area.
You need to set these areas.  I typically set them 10 words apart.
The first word of the control area determines what screen is displayed.
Zero is not a valid number.
See the V069 manual section 2-2-3 for more information.
gtsuport
Well call me stupid
I read that and read that and i dont understand what they want
Do you have a simple example ? Because I find Omrons manuals to be very confusing.
Just a simple read from a DM value will do
Rob
This is a communication issue.
That won't work. Here is the PLC to PT cable.
Mr_PLC_PT_PLC_Cable.thumb.JPG.eb8d917a22
  • Like 1
I do have 20 free conservative DM. For the NT21. I was listening…
i am scanning QR codes into a DM then searching a database for a match.
This PLC has built in Ethernet, sure is nice and very fast connecting to my laptop.
I want to use the NT21 to load the database.
I tried everything to get that screen running. I was starting to think this has to be a cable issue. Or maybe I was loosing my mind……
But I thought for sure I read that if you can load the screens with the NT series support tool it would work between the PLC and the NT21.
I sure wasted a lot of time time on this.
I will make the cable and crossing fingers it solves the issue.
Thanks for the reply guys. Really appreciate it. Be a lot easier to learn with more examples…..
PT Control
I had it started at DM0000
PT Notify                 DM0030
But I will set them to what ever you say..
Rob
Edited by Robafe
2 hours ago, gtsuport said:
Whatever number you enter in DM0000, that screen will be displayed on the NT.
gtsuport
OK I am making the cable now..
Rob
Works like a Charm
I have a scanner connected to Com2 and the NT21 on com 1
I have it display the scanned bar code
Now to expand on that
Thanks for your help
Rob
Quote
Robafe said:
Ok I found another poorly described command
The SRCH command
I have it working to find the data but I want to use the (= flag) to tell it found a match
How do you use it.
It has no address like the serial prts do eg A392.06 ect
I cant find any info on how to use the = flag
Rob
Quote
Equals flag is addressed P_EQ or CF006.
gtsuport
