EasyBuilderPro black background into menus
Go to solution Solved by ematra,
Hello everyone!
Does someone know why at easy builder pro background and text for some menus are both black. I cannot see what is written and of course I cannot program my HMI.
There are some pictures attached.
All other menus are ok, only a few have problems.
Thank you!
  • Like 1
Hello Catalin, if I dont miss something, you should be able to double click on those Icons or labels and select the Color from Font / Attribute option or something like that. Sometimes you find Black font because they are on Grey Buttons so if the Button disappears the Font will be no more readable.
  • Solution
Hi everyone, just want to share the solution I just found, hoping that works.
In the program folder (eg, c:\EBPRO\) you should find an application called DisplaySetting.exe
Run it and select Software render, then Ok. After this close EasyBuilder Pro and run it again and it should run as normal.
  • Like 1
Commenting to let everyone know this worked for me as well. I specifically ran into this issue when running EBPro on a hyperV desktop environment.
