Company wants a digital pressure switch panel mounted in a 8x8x6 enclosure on a machine, near where the operator stands for ease of adjustment. The enclosure will also have two 120v indicator lights. They want lights and pressure switch to be door mounted. I have seen many vacuum switches panel mounted but never a 120psi mounted in a panel with 120v and never seen one door mounted. The enclosure has a side hinged door that will swing open. Is this practical to do? How do I plumb the pressure switch so that it can swing open with the door? Has anyone seen 120psi fed into an electrical enclosure? Thanks.
Not a problem.  Just need flexible tubing with an extra loop or two to accommodate the swing of the door.  Minimum bend radius might be trouble in that small a box.  Also, in the U.S. in all codes I'm familiar with, the box will need a screw clamp closure or a door interlock due to the 120V.
Given this is happening in the USA it seems, I'll throw one small flag on the idea.
NFPA 70E & Arc Flash  - If an Operator is having to open a panel to adjust the switch and there is exposed 120 VAC inside, NFPA 70E guidelines will need to be applied.
  • Like 1
