Hi,
Not sure if it's the best forum to ask this question, but:
We are about to add UV banks to our filtration system, what is the correct name for an UV transmittance analyzer?
For example, for flowmeters, it is FT-X or FIT-X, but what is the name for the UV transmittance analyzer?
Regards,
The tags are usually based on ISA standards.  You can see the tables for ISA codes here:
https://instrumentationtools.com/isa-codes-symbols-for-process-instrumentation/
UV transmittance is not widespread enough to warrant its own category like temperature (T) or pressure (P).  It might be considered an Analysis (A).
There is provision for using a key table for defining exceptions.
Why not UVTT or UVTA for UV Transmittance, Transmitter or Analyzer?
If I read UV anything, I'd immediately associate it with Ultraviolet something.
  • Like 1
