asteroidehk Posted March 7, 2022 Report Posted March 7, 2022 Hello Friends I have a machine with a barcode reader connected through serial port to a GS2110 HMI and a FX3G CPU. Where can I found the tag that is configured to receive the barcode? o how is it configured? I have searched in the HMI program but without sucess. Thanks in advance. Quote
VeeB Posted March 9, 2022 Report Posted March 9, 2022 Hi, Check the settings in GT Designer 3, in Menu -> Common, Peripheral setting, Bar-code Here you would normally find the settings for the barcode reader and the PLC device where the information string is stored from the barcode reader. Quote
