Arpad Nagy Posted March 11, 2022 Report Posted March 11, 2022 (edited) Hi All, Unfortunately due to the current situation, we cannot build a homogeneous system So we need to control several MX2, JX, RX and Yaskawa Inverter (~20pcs) with same CP1L-E PLC if possible. I can control them separately: - Omron Inverters with function block INV002_Refresh_X31 - Yaskawa inverter with "traditional" modbus commands (D32300 and 640.00) How do I control MX2 without a function block? I can write frequency and read parameters, but can't start/stop it. I couldn't find a universal function block or other solution which I could use for all of them. I want advice, is it possible control all with CP1L-E? If so, by what a method? I really appreciate any help you can provide! Edited March 11, 2022 by Arpad Nagy Quote
