Hello everbody i need a little bit of help with my counter. So basically i have a counter that shows numbers on a hmi screen and when the counter counts down from 10 000 to 1000 i need to create a function that make that my right numbers picks up the numbers from the middle counter and countinues to count down. any tips on how to program this in cs/cj
A timer has 2 output elements to it. A BOOL that will turn ON when the value reaches 0 (zero). The other element is the current value. The compiler will choose which to use depending upon the instruction used. You will reference it the same (Tx). It's kind of like a hidden structure. Be mindful of the timer's Data Type. In this example I'm using a Binary (or Decimal) timer and preceding my value with a '&'. A BCD timer will require a preceding '#'.
Mr_PLC_MonitorTimer.JPG.4f9812d4755c8c87
Quote
This sentence makes no sense to me.
If all you need is to force a counter to specific value, do it by MOV instruction.
I guess I was still sleeping this morning..... Here is an example comparing to the counter. Same rules as the Timer. Also, to Sergei's point, an example to modify the current value.
Mr_PLC_ModifyCounter.JPG.6bde72977bde93d
