Hello everyone I'm new to omron plc . I have a system which consists
1. Omron Plc CP2E
2. Two stepper motors and their drivers.
3. 4 Inputs-  one stepper start push button, second stepper go back push button, third stepper 1 home sensor, fourth stepper 2 home sensor
4. 4 Outputs- stepper 1 step(-) Q 100.00, stepper 1 dir(-) Q100. 02, stepper 2 step(-) Q100. 01, stepper 2 dir(-) Q100. 03
Seuence is like that:-
Initially both stepper motors are at their home sensor.
When start push button is pressed both stepper move 110 mm distance and then stop.
Now when go back push button is pressed both stepper motors should go back to their home sensors and should stop at reaching their hone sensors.
This is the sequence. Can someone please send me the program by writing in cx - programmer or upload the photos of ladder program and settings also. Please
Edited by vipin
No.. I didn't get the solution. If I get the solution I will post it here. And you can post if you get the solution before I get it.
Edited by vipin
