kckku Posted April 27, 2022 Report Posted April 27, 2022 For some reason I am not able to use Test Mode for one of my HMI projects. It's giving me this CX-Server error. Does anyone know why this is? It's only on one of my projects. Other ones seem to work without issues.
photovoltaic Posted April 27, 2022 Report Posted April 27, 2022 Which mode are you using with the Test?
kckku Posted April 28, 2022 Author Report Posted April 28, 2022 19 hours ago, photovoltaic said: Which mode are you using with the Test? Trying to connect to the PLC. Is this what you mean?
photovoltaic Posted April 28, 2022 Report Posted April 28, 2022 Cx Server is known to hang up at times. Have you tried restarting your PC? This has cleared CX-Server errors for me before
kckku Posted April 28, 2022 Author Report Posted April 28, 2022 1 hour ago, photovoltaic said: Cx Server is known to hang up at times. Have you tried restarting your PC? This has cleared CX-Server errors for me before I already restarted the PC a few times. The other weird part is that this is the only project file that it's happening to. We have three HMI's on this machine and the other two HMIs and projects are working OK. I also tried it on my own laptop and it's the same issue. Can't use Test Mode for this one project and HMI. I actually don't even know what CX-Server is supposed to do. Never had an issue with it before.
photovoltaic Posted April 29, 2022 Report Posted April 29, 2022 19 hours ago, kckku said: I already restarted the PC a few times. The other weird part is that this is the only project file that it's happening to. We have three HMI's on this machine and the other two HMIs and projects are working OK. I also tried it on my own laptop and it's the same issue. Can't use Test Mode for this one project and HMI. I actually don't even know what CX-Server is supposed to do. Never had an issue with it before. Can you share the program?
kckku Posted May 2, 2022 Author Report Posted May 2, 2022 On 4/29/2022 at 10:14 AM, photovoltaic said: Can you share the program? I will have to see if I can share the program.
kckku Posted May 9, 2022 Author Report Posted May 9, 2022 On 4/29/2022 at 10:14 AM, photovoltaic said: Can you share the program? It doesn't look like I can share the program. Unfortunately. I tried uploading a fresh project and then downloading it again to the HMI. Still no luck. Also tried different PC and laptop and still no luck. Really not sure anymore.
