sanisti Posted April 28, 2022 Report Posted April 28, 2022 Hello evreryone! I want to build a Gx Work program. The condition for auto start is when a low limit sensor is detected. When the high limit sensor is detected, supply to the tank is stopped. The order in which the tanks are opened is 4,3,2,1. Tank closing order is reversed. Valve 5 must be closed when liquid is being supplied to the tank. The completion of supply to the tank is confirmed by the high limit sensor. I use MOV transfer e.x D0 K1 Y01 MOV K2 D0 Y2 Y3 I want to open coli Y1 Y2 Y3 every valve how to open toether. Thank you
