NotaMaster Posted May 25, 2022 Report Posted May 25, 2022 Hello, can i use the same address for my HMI and SCADA? Example for the button in my HMI is %M8 and i use the same address for button in SCADA system? Quote
Joe E. Posted May 25, 2022 Report Posted May 25, 2022 Theoretically....maybe. I've worked on HMI migrations where I had old and new operating side by side and it went ok...on the bench. But I wouldn't try to do so in the field. Having two devices control the same thing is generally not a good idea. Quote
NotaMaster Posted May 26, 2022 Author Report Posted May 26, 2022 7 hours ago, pturmel said: Generally not, in my experience. Okay sir, thank you. I will use a different address just in case Quote
NotaMaster Posted May 26, 2022 Author Report Posted May 26, 2022 7 hours ago, Joe E. said: Theoretically....maybe. I've worked on HMI migrations where I had old and new operating side by side and it went ok...on the bench. But I wouldn't try to do so in the field. Having two devices control the same thing is generally not a good idea. Thank you sir, i will use a different address Quote
BobLfoot Posted May 26, 2022 Report Posted May 26, 2022 I have seen one case where this was done. The PLC had a tag "Motor_Start_PB" and each HMI was configured to toggle on "Motor_Start_PB" but never to hold it on or turn it off. The PLC code then at the end of scan had an Unlatch Motor_Start_PB if it was on. This worked, but you never knew which station started the machine. Quote
