abcnik1 Posted June 4, 2022 Report Posted June 4, 2022 hi i have a fx1s-20mr 001 controller it has stop working on one of the outputs i wanted to copy the program to another unit but it is asking for 2 pin numbers is this locked so i cant access it by the supplying company and is the anyway around this Quote
Ron_S Posted June 5, 2022 Report Posted June 5, 2022 You could repair it. The output relays are replaceable. If you have another unit you can de-solder a relay from one to the other. Quote
