flycast Posted June 13, 2022 Report Posted June 13, 2022 I am looking for an inexpensive PLC to receive a signal or two from sensors, build a MQTT packet and send it to AWS. AWS only allows encrypted packets so it needs to support MQTTS. This is also known as an IOT gateway. I have sound a solution for a gateway that costs $750 - $950 each. I am now looking to reduce the cost. Does anybody have any recommendations? Quote
panic mode Posted June 13, 2022 Report Posted June 13, 2022 you can get ESP8266 for couple of bucks if you are looking for something more ... DIN-rail style... check Automation Direct https://www.automationdirect.com/adc/search/search?fctype=adc.falcon.search.SearchFormCtrl&cmd=Search&searchquery=mqtt&categoryId=0&TxnNumber=-1&searchqty=10 Quote
