Hi.
I am using PLC Q06UDV wit QD77GF to operate 11 servos, it is my first time using QD77GF and CC-Link IE Field. I've done the parameter setting. but the qd77gf error lamp started to blinking. i try to check it in cc link ie field diagnostic and didn't find anything except the error lamp blinking in monitor view. then i checked system diagnostic , no error showing up but, only historical error when i started the power of plc. it show D304 error.
in manual book the solution are lengthen the operation cycle qd77gf, check the cable, and shorten plc scan time. where can i find this setting sir?
