scotty134 Posted June 17, 2022 Report Posted June 17, 2022 Hello, I am curious, is it possible to use Data Tracing tool to use it without PC connected to a PLC? I want to keep saving data on SD card installed on PLC while it's running on its own. I tried to use sampling trigger and wrote piece of code that enables sampling, but no luck with saving the data to SD card that is installed on PLC. What am I doing wrong? Thanks, Scotty Quote
photovoltaic Posted June 18, 2022 Report Posted June 18, 2022 It does save to your PLC. You can set a trigger condition and then go offline. Next time you connect you can load the trace if the trigger happened. I don't believe you can save it to the PLC SD card though. Quote
scotty134 Posted June 20, 2022 Author Report Posted June 20, 2022 On 6/18/2022 at 6:43 AM, photovoltaic said: It does save to your PLC. You can set a trigger condition and then go offline. Next time you connect you can load the trace if the trigger happened. I don't believe you can save it to the PLC SD card though. It will be an awesome feature if I could save Data Trace to internal SD Card. Quote
