Hi All,
I have a problem with my GXWorks2. When open new file or opening any files related to GXWorks2 always saying "Cannot execute the operation because memory is insufficient or system is unstable. Please execute again after closing other applications or reinstall GXWorks2".
I've tried to unistall using cleanup tools, and then re install with normal mode, administrator rights, even using compatibility modes. But always ended up with same message.
Also try to install via GXWorks3 and GXWorks2 stand alone, ended up with same thing. But while Installing via GXWorks3, GXworks3 running well, GXWorks2 same message, when using GXWorks2 with GX Developer, only GX Developer is running.
Any suggestion please. Thanks in advance.
Before starting GX Works, try using Ctrl Alt Del and start Task manager.
Shut down as many running processes as you can and try again.
Hi Ron_S,
Thank you for your advice, i've trying to do so, but no result, finally i do windows repair, than it works.
Some windows update have issue with compatibility.
