Good Day everyone i'm just really new in PLC programming using M221 series on Ecostructure basic. Can someone help me to make a program that will ON/OFF one digital output depending on the temperature setpoint of thermocouple input (module TM2AMI2LT). Thank you so much
@Maryn You need to read data from analog input (They are in %IWX.0 or %IWX.1 depend on which channel do you use) then use compare block to enable with output.
