pszczepan Posted July 6, 2022 Report Posted July 6, 2022 Hi I can't find IP of PLC. I tried to use below procedure https://www.myomron.com/index.php?action=kb&article=1487 but still no success. I attached printscreens and I don't know how I can get mentioned IP 169.254.XXX.XXX . I did as Myomron suggested - tick OFF and ON "Disable The direct Ethernet" Any clue?
pszczepan Posted July 7, 2022 Author Report Posted July 7, 2022 As I wrote i did tick OFF and ON and nothing changed
photovoltaic Posted July 7, 2022 Report Posted July 7, 2022 Is there an Ethernet switch in between your PC and PLC?
photovoltaic Posted July 7, 2022 Report Posted July 7, 2022 (edited) 19 hours ago, pszczepan said: I don't know how I can get mentioned IP 169.254.XXX.XXX . This is what the Direct Ethernet Utility creates when it is active. If you enable it and enter ipconfig /all in the command prompt you should see the 169 address. You'll have 2 IPV4 addresses: Edited July 7, 2022 by photovoltaic
panic mode Posted July 7, 2022 Report Posted July 7, 2022 2 hours ago, pszczepan said: As I wrote i did tick OFF and ON and nothing changed that is exactly opposite of what is in linked instructions and suggestions. when checkmark is set, function is disabled.
Michael Walsh Posted July 12, 2022 Report Posted July 12, 2022 On 7/7/2022 at 0:53 PM, panic mode said: that is exactly opposite of what is in linked instructions and suggestions. when checkmark is set, function is disabled. I believe that he is saying that he did both (on and off) and it did not work either way. I would suggest unchecking the box and connecting directly to the PLC with a cable (no switch) as photovoltaic was suggesting.
pszczepan Posted August 24, 2022 Author Report Posted August 24, 2022 I decided to check it on other PC, and it is working as it should. The same system win7 64bit, the same software Problematic PC has a problem to get second IP IP 169.254.XXX.XXX. No switch, direct connection. Do you have any idea what global network/windows settings can block it?
photovoltaic Posted August 24, 2022 Report Posted August 24, 2022 8 hours ago, pszczepan said: I decided to check it on other PC, and it is working as it should. The same system win7 64bit, the same software Problematic PC has a problem to get second IP IP 169.254.XXX.XXX. No switch, direct connection. Do you have any idea what global network/windows settings can block it? I have seen windows block this a few times. It generally happens on computers that have either strict and locked down networking rules or a lot of networking type software (VPNs, IIS utilizing programs). On every occasion I have seen it I have been able to make a connection by IP address,
pszczepan Posted August 26, 2022 Author Report Posted August 26, 2022 If I know IP address I can connect without any problem, but sometimes IP is unknown for me and Middleware solution would be useful for me. Did you investigate how to switching off such a blocking?
