Thanks for your response Gambit
We need to have message on HMI for operator after say every 20 cycles, to clean up torch in MIG welding application, similarly to cut wire before resuming after power cut because if that is not done, torch gets bent during homing cycle
ok just create some window screens with those messages. (and a close window button)
Now go to the system tab  => enviromental setting => screen .....
change the overlap window device to a PLC register or add a second one.
Now from the PLC mov the nr of your window screen to that device and the window screen will appear
