simonongsk Posted July 19, 2022 Report Posted July 19, 2022 Hi: Has anyone use Fins Command with NX1P2 (or any NX/NJ). I try with Multiway with "[!]: Command format error (1004)" Below is the command from multiway 800003000100000100060101820001000003 Data memory are define in global variable table as A as %D1, B as %D2 and C as %D3. The relevant setting are done on Fins Setting and Memory Setting in the PLC. Anyone ? Quote
Michael Walsh Posted July 22, 2022 Report Posted July 22, 2022 This was answered in the other post. You are using an NX102, not an NX1P2, right? Only port 2 supports FINS on the NX102. Quote
