Jump to content
Posted
Hi,
I'm developing an application in C# and need to communicate with a plc omron NX1P2. How can i do it? With cx-compolet?
Or is there another way?
Posted
The NJ and NX processors support symbolic access via Ethernet/IP using the same read & write services as Rockwell uses.  See Rockwell's Logix 5000 Data Access manual.
  • Like 1
Posted
I've used socket services for this in the past. Essentially send TCP commands like you would over Telnet and parse them out in the PLC.
  • Like 1
Posted
On 9/30/2022 at 4:44 AM, casofp said:
Hi,
pturmel said nice stuff. You can use E/IP library for .NET and your communication will be more advanced, compare to old fashion TCP/UDP styles. I'm not saying that it's wrong or so. TCP and UDP still valid and very useful communication protocols. But E/IP will be a bit comfortable and convinience. PLC won't require to do extra steps to build a message for transaction and your application won't need to parse the data.
Posted
It's very easy to create a socket and exchange data by UDP or TCP.
You can exchange data in structure without conversion.
  • Create New...
