kckku Posted October 3, 2022 Report Posted October 3, 2022 There is a column in the Task Settings tab that is titled 'Detailed Execution Conditions'. Any idea what this column is used for and how to use it? The Omron NJ/NX-series CPU Unit Software User’s Manual (W501) doesn't show this. Section 4-2-3 explains all the other items but doesn't have a description. Has this always been here and I just never noticed it? Or is this something new that came as a result of a version update? Quote
PMCR Posted October 3, 2022 Report Posted October 3, 2022 This has always been there. This setting is only used for Event Tasks, set for 'When a variable expression is satisfied'. This is where you create the variable expression to trigger the event task. Quote
