DieterG Posted October 17, 2022 Report Posted October 17, 2022 Hello, I just installed the Step 7 V5.7 on my windows 10 laptop. Was running the Step 7 V5.1 SP3 version on a virtual machine before. Found out that my old rs232/MPI-DP adapter is not supported anymore. So i have to buy a new adapter. instead i was thinking to connect with ethernet so i don't have to leave my desk every time i make some changes. I guess i need the CP343 module for this ? Now that one is really expensive. Does anyone know any other options ? Thank's for the help. Dieter. Quote
acpi Posted October 17, 2022 Report Posted October 17, 2022 (edited) Morning, You could use indeed a CP343-1 Lean card wich is the basic version of the CP343 but it's still very expensive and probably not available at all at the moment. A cheapest solution is to use an Ethernet/Profibus gateway (yes another gateway ;-)) like this one : https://www.ibhsoftec.com/epages/63444704.sf/en_GB/?ObjectPath=/Shops/63444704/Products/20266 I never used it but IBH is well known for their compatible Siemens products. JC Edited October 17, 2022 by acpi Quote
DieterG Posted October 17, 2022 Author Report Posted October 17, 2022 Thanks for the advice. I have a siemens hmi laying around. This one has profibus and ethernet connection. Would it be possible to program the plc thrue the hmi? The hmi is currently not used, i don't have wincc to program it. Quote
acpi Posted October 17, 2022 Report Posted October 17, 2022 (edited) Sorry but you can not use the HMI as a gateway. Go for the IBH (or similar) gateway or try to find an used CP343 at a decent price. Edited October 17, 2022 by acpi Quote
Joe E. Posted October 17, 2022 Report Posted October 17, 2022 I've used the IBH gateway before and it worked reasonably well but initial setup was a bit involved and it was expensive. I don't know how the price compares to an in-chassis module, but it does simplify things in that it isn't added to the PLC's hardware configuration. Quote
DieterG Posted October 18, 2022 Author Report Posted October 18, 2022 Thank's everybody, Wil try the IBH gateway. Does anybody have tryed a android app to read and change bits ? Quote
