kckku Posted October 19, 2022 Report Posted October 19, 2022 So we got this notice from our IT group this morning regarding an issue with a malicious program execution vulnerability with Omron (and Siemens) PLCs. https://www.ia.omron.com/product/vulnerability/index.html I read the notice and it basically recommends updating the controller firmware for the PLC. Is this something that we can do ourselves or do we need Omron to do it? Quote
photovoltaic Posted October 19, 2022 Report Posted October 19, 2022 1 hour ago, kckku said: So we got this notice from our IT group this morning regarding an issue with a malicious program execution vulnerability with Omron (and Siemens) PLCs. https://www.ia.omron.com/product/vulnerability/index.html I read the notice and it basically recommends updating the controller firmware for the PLC. Is this something that we can do ourselves or do we need Omron to do it? This is something Omron does. Quote
BobLfoot Posted October 19, 2022 Report Posted October 19, 2022 3 hours ago, kckku said: So we got this notice from our IT group this morning regarding an issue with a malicious program execution vulnerability with Omron (and Siemens) PLCs. https://www.ia.omron.com/product/vulnerability/index.html I read the notice and it basically recommends updating the controller firmware for the PLC. Is this something that we can do ourselves or do we need Omron to do it? Do you also happen to ahve the Siemens Advisory Link? Quote
kckku Posted October 19, 2022 Author Report Posted October 19, 2022 1 hour ago, BobLfoot said: Do you also happen to ahve the Siemens Advisory Link? Here's the Siemens link: https://cert-portal.siemens.com/productcert/html/ssa-568427.html Quote
BobLfoot Posted October 21, 2022 Report Posted October 21, 2022 On 10/19/2022 at 0:23 PM, kckku said: Here's the Siemens link: https://cert-portal.siemens.com/productcert/html/ssa-568427.html Thank You Quote
SKA AB Posted October 28, 2022 Report Posted October 28, 2022 We got the same from our IT-Department at my current client. With Siemens, you can upgrade the firmware your selves, just take precatious to backup the code in the CPU, and if there are important variables/settings in DB's that are important, make sure to copy the values to an offline copy just in case something goes belly up. I would connect with a current project, open the important data blocks and copy current values into startup values, just to have it saved off the cpu. Quote
